- Jun 9, 2002
- Omaha, NE/Ithaca, NY
MameXP said:ye normally you want Rad right after the pump, so here is the better loop:
pump -> rad -> CPU -> GPU -> pump.
How does the fans mouted on the rad? Any ducting?
Changing his loop to put rad right after the pump probably won't make a noticable difference. It has been calculated that you would probably lose .5C, but if you have to use more tubing and have more bends in your tubing, then you probably won't see any difference.
