thin radiator?
s002wjh
been out of WC for a while, just like to know which thin under <50mm radiator for LPM fan, yate loon 1200-1600rpm is the best? 240mm
1200-1400 rpm is about the break point between the swiftech qp (12fpi) and swiftech xp (20fpi) for performance. If you think 1200 will be the max you run your fans at get the qp or another similar fpi rad. I run 1450 rpm fans in push/pull on a swifrech xp rad with great results.
