- Mar 12, 2007
i'm thinking of just reformatting and using windows again, maybe nlite. :/ linux just seems like a hasstle to configure for everything to work...
Well the only thing you said didn't work was your wireless?
Connect to your network through the ethernet port and try this out http://www.kubuntuway.net/forum/showthread.php?t=57
The first two steps are key as this will determine if it is the same problem or not. Oh and you will need to do that from a console. I think in Ubuntu (sorry Kubuntu user here, things are different) you can press alt+F2 and it will bring up a run box. Type in console and a console window should pop up. If that does not start a console then you could just navigate through the applications menu, I think the console is under either system or utilities. I'll fire up a VM of Ubuntu when I get home and correct myself latter.
As for the printer, just plug it in and find the printer setup. I was able to get my mothers all in one printer to work perfectly out of the box in Ubuntu, even the print and scan buttons on the printer start up the default programs for those functions.
