This WILL be my rig.
HarlanC
As of now I have no money :rolleyes: So this will be my future rig. Any comments or suggestions are welcomed.
Case - Thermaltake Armor Series VA8000BWS Black or
Cooler Master Stacker Black
Motherboard - DFI LANParty UT NF4 SLI-DR
CPU - AMD athlon 3700+ San Diego
PSU - OCZ Powerstream 520W
Video Card - Geforce 7900GT
HDD - 2X Seagate 320gb Sata 2
Ram - G.skill 2gb DDR500
And right now all I have out of this list is the CPU and the ram :bday:
UnrealAlex said:
Is there even an AM2 3700 processor?
If not, why do you have DDR2.
What? The processor I mentioned above I currently am using.
You have an MM U2 UFO in the pic but you use a TT case???
We WILL want to see the pic of your new rig...
Well this is just a half assed case a friend of mine made. There is only the front panel and I positioned the motherboard tray stupid cause I was in a hurry and of course I will post, but now Im thinking of going with the CM Stacker case instead. I dont know. Any suggestions?
Any opinions on which case I should pick? Im leaning towards the CM Stacker.
Getting such a good case for a single core?... I wouldnt put out all the money just on the case and have a single core... Thats just my opinon though, other wise the case is all right.
Well Im going to be modding this case and probly using it for a long while. As in whenever I next upgrade after this. Also, I am waiting to see what the AMD quad cores are going to be like. If they arent coming out for a long *** time then I may just invest in a dual core.
