- Nov 12, 2011
So I had an issue where turning on my pc caused it to make 4 beeps and keep restarting before the monitors would come on. I took out the far memory stick and it would start. For a test I replaced the near memory stick with the far one and it wouldn’t start so I concluded it was the stick.
Today the new stick arrived and I put it in the far slot. 10 minutes into what seemed to be a successful fix, the pc crashed and when I rebooted I heard those dreadful 4 beeps.
My plan is to get another stick and use the other two memory channels on the mobo. I’m assuming something is wrong with that far slot. Does this sound like a good plan?
Also, for the time I’ve had this pc I was using the “secondary” two ram slots because the first looked too close to the cpu cooling fan. I tested the ability to use that nearest slot and I can fit a stick in there.
