Heh... this is all subjective... Here is my thinking:
1. What is the recommended quick test method to check an overclock for stability (less than an hour of testing)
Linx/Linpack/IBT/OCCT - Those are massive overkill applications. To me its akin to driving your car past redline to the rev limiter. So that is quick, dirty and way more stressful than P95 and a decent way to quick check stability.
2. What is the recommended good test method to check an overclock for stability?
I use Prime95 Small FFT for 8 hours to test CPU, then another 8 hours on blend.
3. What is the extreme recommendation to ensure you almost definitely won't see a crash under almost any condition
24 hours P95 Small FFT, than 24 hours blend.
To add to that, using the application/game and it doesnt crash.
EDIT: Just read the entire OP - IMHO Prime is still a contender in the game. Like I mentioned above, those programs, to me, appear to run your CPU past redline. Im at 100% load with P95, so what does Linx/Linpack/IBT/OCCT do more EXACTLY?? Integers? FPU? What does it do OVER Prime that makes it better? I cant get my PC to reach P95 temps, none the less those applications temps which are a few C higher. Thats why I believe that although Prime95 may be slower at finding errors, its no less effetive, hence my method.
