- Nov 12, 2002
- Rootstown, OH
Joe Citarella did some good testing about paste application patterns. Didn't matter much, except you shouldn't attempt to spread the paste using a razor blade or credit card - its more likely to result in uneven coverage resulting in air gaps.
Center is best, or a line following the alignment of modern die. I use a peasize amount in the center, then let pressure spread it out.
When designing your hold down, don't worry too much about pressure - apply a lot, but not enough to flex the PCB or crush the socket. Preferably, you want to ensure the pressure is even around all sides. The easiest ways to go wrong are to not apply enough pressure, or to flex the mobo PCB which could cause traces to fail eventually which would cause errors or mobo death.
From experience strapping really heavy copper pots onto processors, its hard to apply too much pressure, especially if you use a backplate that reinforces the mobo.
And welcome to OCF!
And welcome to OCF!
