Budget: None as of now
Theme: Black/White
Uses: Everyday Use/Overclocking/Gaming/Hobby
Purchased Main Components:
CaseLabs Case STH10
ASUS Maximus V Extreme Z77 E-ATX Motherboard
Intel Core i7- 3770K 3.5 GHz
EVGA 680GTX PCB
Crucial 512GB SSD
Corsair Dominator Platinum 16GB 1600MHz
Corsair AX 1200 (Planning for future additions of GPU)
Watercooling Products for SINGLE loop:
1 XSPC Raystorm CPU Block
1 Heatkiller GPU Block
1 XSPC D5 Dual Bay Reservoir/Pump Combo
1 XSPC RX 480 Radiator
1 XSPC EX 480 Radiator
16 Yate Loon D12SM-12
10ft PrimoFlex Pro LRT 3/8 Tubing
Silver Bezel Wire, .999 Fine Silver 12" strip
10-12 Compression Fittings 3/8
Feser Aqua Ultra Pure Non-Conductive Water
My questions are:
1) Will those Yate Loon fans work well on an EX480? Should I just purchase another RX480? I didn't think it was necessary even though I have no budget constraints.
-I may add one more GPU to this build if I feel that one 680 is not sufficient.
2) Where's the optimal locations for my radiators? I was planning to have them on the sides of the bottom to draw in colder air through the radiators. I will most likely have exhaust fans on the top for the rising hot air.
3) Are the two radiators listed above adequate to plan ahead for an extra 680 in the loop?
4)Should I try running things in a particular order? I was planning to put them in this order: Pump/Reservoir => 2xRAD => CPU => GPU
5) Is that D5 Pump going to be sufficient for the 2x480 radiators?
6) Would it be okay to add distilled water with that Feser fluid?
7) All the parts I purchased are copper, but I don't think the fittings are and I'm worried about corrosion in the long run. What about that silver? Would it cause corrosion?
Thanks guys for taking the time to read this! Hopefully all you guys can chime in with any constructive criticism/advice/feedback!
***This is the same exact post I made on XS as well. I wanted the most input I could get from both of these forums. As questions get answered, I will edit them out of the posts.
Theme: Black/White
CaseLabs Case STH10
EVGA 680GTX PCB
Crucial 512GB SSD
My questions are:
