does this pump have the balls for cpu,northbridge,and mosfet block, then later adding a 4870 block , should this be divided into two circuits two smaller rads 2 pumps? or will a quad 120 be enough? 90% oc'd e6300
Yes, the pump will be plenty for all those blocks. I also agree about the Feser Quad radiator over the GTX.
that gtx 480 will work just fine. dont know y everyone puts the fessar out there like that. they act like gtx are crap. GTX series rads is all i use. from the 120, 240, 360, now the 480
i run the same pump, on my loop at setting 1.
i use a gtx480 and it cools just fine with all my fans at a low 900rpm.
idle/load cpu
32/45c(prime) 51C(IBT)
idle/load cpu
If space isn't an issue, why not grab a pair of MCR 320's and run them in series. Would give you BETTER cooling than a single 480 and save you $40+.
Axis
