Trouble using Windows XP ISO image to make bootable dvd
So I built a system of all brand new parts:
i3 530
EVGA P55 LE
GTX 460
WD 15k velociraptor 300 Gig
2X2G G Skill Ripjaws
Thermaltake 750 W
OEM Asus Optical drive (unsure on model)
And my Windows XP disc is not working. After trying to remove some RAM, someone mentioned in another thread that my pre-service pack XP disc is probably not recognizing my new hardware. So I downloaded an iso image of Windows XP that includes SP1-3 through my University. I also downloaded BurnAware and used it to create and burn the disc.
I have no problem burning the iso to disk as a data disc (which does nothing when I try to use it), however I run into trouble when I try to burn a boot disk.
These are the steps that I am taking:
1. Select "Make Boot Iso"
2. Successfully create and save a Boot ISO from the downloaded ISO.
3. Select the option to burn a boot disk.
4. Add the boot disk .iso file I created and hit the "burn" button.
5. I then get a prompt that says "Please specify boot image file in Options>Boot."
When I go there and hit browse to select an .img or .ima I have no idea where to go or what to look for. I did a search and found websites talking about creating boot image files but they all seemed to be giving instructions on creating a boot disk using an already installed OS or for a bios flash - not from an already created iso as far as I could tell so I can't see what is relevant and what is not.
Using ISO Master I am able to examine the ISO and everything looks pretty straightforward internally but I am unable to readilly see any .img or .ima files although I admittedly only gave a cursory lookover.
Any suggestions on where to go from here?
Also, as a side note, the boot settings are set to "automatic." Please let me know if these might need to be adjusted:
emulation type: Floppy emulation 1.44mb
platform: 80 X 86
Sectors: 1
Load Segment: 1984
Boot Message: Burnaware Boot Loader
Thanks for all your help!
i3 530
EVGA P55 LE
GTX 460
Thermaltake 750 W
platform: 80 X 86
Sectors: 1
Load Segment: 1984
