- Mar 12, 2002
Hey guys!
So I just got a new 8Tb HDD to replace my aged 2Tb HDD that I use for data storage.
Drive D: under properties shows 1.02TB of data. I deleted all the junk I don't need.
I enabled show hidden files and folders(only thing was a msdownload.tmp 0kb.
Ok so I select all folders from the drive root and copy to new drive E:.
Data transfer completes without an issue.
Check drive properties and find that the used size is 957GB.
First though is ok I must have enabled compression - nope.
Casually navigated the folders and seems to be right.
So I waited a few days for it to index everything and then checked a couple of my larger folders and got file count matches.
Still uneasy about the situation I decided to reformat the new disk, and run the transfer again.
Again the transfer completes without an issue.
And again I have the exact same mismatch. D: 1.02TB E: 957GB
2TB disk originally formatted in windows 7 with MBR / NTFS setup.
8TB disk formatted in windows 10 GPT / NTFS setup.
I know the new drive is setup with 4K block size, but I dont remember what I set it to on the old drive.
Appreciate any insight you can provide.
