Hello, I am trying to put together a new workstation and I've run into an issue with my triple monitor setup. I am working with a brand new Dell Optiplex 9020, which has an R7 250 GPU. I have two U2414H monitors which came with the order as well. The first monitor I plugged into the GPU using the mini DP port and the second monitor is daisy chained of the DisplayPort. The two of them work fine once I enabled DisplayPort 1.2 on the monitors.
I took an older P2210 monitor, which has a DisplayPort as well and added it to the daisy chain. I was sure to make sure DisplayPort 1.2 was enabled on both the U2414H monitors.
AMD Catalyst detects all three monitors but I can't seem to extend the desktop to the third one. It asks me to disable a monitor before I can continue. I'm under the impression that my video card is capable of having four monitors extended at the same time, and using DisplayPort is how to accomplish this.
I even unplugged the P2210 and used the DVI connection and it was no different. Why can't I do this?
