Hey!!! Happy to hear you got the stuff.
I definitely agree with you about their SAS cables, they are way too long. Unfortunately all SAS cables are stiff. I happened to purchase 2 of
these several weeks back, was a little bummed out when I was told that the case comes with SAS cables "complementary" but am now happy again that I have something of the correct length, and the quality is good. Get something else from monoprice as well b/c of their shipping charges. (I got a modular crimper and rewired my entire house's ethernet and phone lines to custom, exact length cabling.)
I was up till 1 am yesterday/ today putting stuff together. Technically, I've put everything together (motherboard mounted and wires connected), components in generally correct positions, etc, with a few exceptions. I still have to finish plugging in my own SAS cables (cutting their zip ties off is fun, but be careful). Also I think I'll have to route them under the motherboard to make them fit.
The case coolers present an interesting issue. Each has its own 3 pin molex connector. My motherboard only has 1 header for SYS_FAN. I'm going to try making a splitter: (all you'd need is a servo y connector from the RC hobby department of interests) but I have
these housings and
these female pins from my electronic circuitry work. Ideally, you'd also need the
male pins and perhaps
a crimper, but I'm going to improvise a little to just use the first 2 items I already have.
Cable management is a nightmare in this thing, aka there is no space to put the cables. Theoretically, I have 2mm - 3mm of clearance between where my 37mm fan ends and the cage wall begins. The way my motherboard is mounted the 24 pin Molex power connector is all the way at the bottom, so that huge bundle of wires had to go between the CPU fan and the 1 stick of RAM (4gb), when I upgrade that to 8gb (2x 4gb) in just under a year it will be an even tighter, might not even fit, situation.
The PCI plate that goes in the back of the case took some pliers and pushing to get into place, and resulted in a few scratches on the case. Also I had to add machine screws and spacers (not included) to elevate the card. My SSD is on the plate, currently held in place by one screw, I may have put it in the wrong orientation.
Finally, I have to bench grind machine screws to hold my PSU in (2 screws to hold it to the back plate, I can't find a way to screw it to the underneath part.
