- Feb 3, 2012
I bought a Tuniq Tower 140 Extreme for my new computer build the other day. I had it installed without the speed controller and it was working fine but i could not get it to lower from 100% rpm. So I just now installed the controller and though the fan in running nothing is recognizing a fan in the CPU Fan plug, thus I am getting warnings. I know the fan and controller are working properly but I was wonder if I should just ignore the warnings because I know them to be false or get rid of the controller and just live with the noise and possibility of premature failure due to the constant high speed?
Note: My speedfan has been showing cpu temp at -60C, though the ASUS monitor shows it at 18C (under load). Is this just a limitation to speedfan?
