I just got everything installed. Every time that I run the Sound check program it tells me to unplug any outside devices when the only thing plugged into it are my dvd burner and dvd player in the cd and aux ports on the sound card. It still fails even when I unplug those. Here are my test results
08/19/04 18:24:26
SCSCHK.EXE: Version 1.01.4158.38, March 21, 2002
Driver: Version 5.12.01.4161-2929, (null)
Windows 5.1.2600 NT
CPU Info: GenuineIntel Family 15, Speed 2793, Model 0, Type 4, Stepping 11080660
Physical Memory: 1048MB
PCI Devices detected:
Communication controller Intel Corp. :2570 Ven:1019 :1875
Communication controller Intel Corp. :2571 Ven:0000 :0000
Unknown Class: 12 Intel Corp. :24D2 Ven:1019 :1875
Communication controller Intel Corp. :244E Ven:0000 :0000
Communication controller Intel Corp. :24D0 Ven:0000 :0000
Search for Santa Cruz Card
Santa Cruz hardware detected on PCI bus.
Test 0: Locate Card on PCI Bus Pass
Hardware Test
Test 9: Load Spud API Pass
CWGMSG_SUCCESS
Found Santa Cruz DSPTest 10: Locate DSP Pass
Default settings restored successfully.Test 7: Restore Default Settings Pass
CWGMSG_SUCCESS
Test 14: Check Audio Matrix Pass
Test 12: Check Codec 0 Pass
Test 13: Check Codec 1 Pass
Voyetra Turtle Beach 46xx Test Software: SoundCheck Version
Codec.(0)...... PASS
Line In.....(0)
L: Levl: 0.075(Min: 0.055) Corr: 1.000(Min: 0.900) Thd: 0.053(Max: 1.000) DC: 0.000(Max: 0.200)
R: Levl: 0.000(Min: 0.055) Corr: 0.005(Min: 0.900) Thd: 0.045(Max: 1.000) DC: 0.000(Max: 0.200) LEVEL FAIL
Test 14: Check Audio Matrix Fail: The device may be not properly installed or is defective.
FAIL
Aux.........(0)
L: Levl: 0.019(Min: 0.015) Corr: 1.000(Min: 0.900) Thd: 0.168(Max: 1.000) DC: 0.000(Max: 0.200)
R: Levl: 0.001(Min: 0.015) Corr: 0.053(Min: 0.900) Thd: 0.147(Max: 1.000) DC: 0.000(Max: 0.200) LEVEL FAIL
FAIL
CD..........(0)
L: Levl: 0.091(Min: 0.070) Corr: 1.000(Min: 0.900) Thd: 0.341(Max: 1.000) DC: 0.000(Max: 0.200)
R: Levl: 0.001(Min: 0.070) Corr: 0.007(Min: 0.900) Thd: 0.371(Max: 1.000) DC: 0.000(Max: 0.200) LEVEL FAIL
FAIL
Stereo Mix..(0)
L: Levl: 0.196(Min: 0.155) Corr: 1.000(Min: 0.900) Thd: 0.132(Max: 0.700) DC: 0.000(Max: 0.200)
R: Levl: 0.200(Min: 0.155) Corr: 1.000(Min: 0.900) Thd: 0.123(Max: 0.700) DC:-0.000(Max: 0.200) PASS
Mic.........(0)
R: Levl: 0.000(Min: 0.001) Corr: 0.078(Min: 0.900) Thd: 0.000(Max: 1.000) DC: 0.000(Max: 0.200) LEVEL FAIL
FAIL
Mic.w/Boost.(0)
R: Levl: 0.001(Min: 0.030) Corr: 0.005(Min: 0.900) Thd: 0.164(Max: 1.000) DC: 0.000(Max: 0.200) LEVEL FAIL
FAIL
Tad.........(0)
L: Levl: 0.036(Min: 0.018) Corr: 0.996(Min: 0.900) Thd: 0.050(Max: 1.000) DC:-0.000(Max: 0.200) PASS
Codec.(1)...... PASS
Line In.....(1)
L: Levl: 0.074(Min: 0.055) Corr: 1.000(Min: 0.900) Thd: 0.048(Max: 1.000) DC:-0.000(Max: 0.200)
R: Levl: 0.075(Min: 0.055) Corr: 0.999(Min: 0.900) Thd: 0.058(Max: 1.000) DC: 0.000(Max: 0.200) PASS
Aux.........(1)
L: Levl: 0.019(Min: 0.015) Corr: 1.000(Min: 0.900) Thd: 0.180(Max: 1.000) DC: 0.000(Max: 0.200)
R: Levl: 0.019(Min: 0.015) Corr: 0.999(Min: 0.900) Thd: 0.177(Max: 1.000) DC:-0.000(Max: 0.200) PASS
CD..........(1)
L: Levl: 0.091(Min: 0.070) Corr: 1.000(Min: 0.900) Thd: 0.411(Max: 1.000) DC:-0.000(Max: 0.200)
R: Levl: 0.091(Min: 0.070) Corr: 0.999(Min: 0.900) Thd: 0.407(Max: 1.000) DC: 0.000(Max: 0.200) PASS
Stereo Mix..(1)
L: Levl: 0.194(Min: 0.155) Corr: 1.000(Min: 0.900) Thd: 0.076(Max: 0.700) DC: 0.000(Max: 0.200)
R: Levl: 0.198(Min: 0.155) Corr: 1.000(Min: 0.900) Thd: 0.084(Max: 0.700) DC: 0.000(Max: 0.200) PASS
Mic.........(1)
R: Levl: 0.034(Min: 0.001) Corr: 1.000(Min: 0.900) Thd: 0.000(Max: 1.000) DC:-0.000(Max: 0.200) PASS
Mic.w/Boost.(1)
R: Levl: 0.167(Min: 0.030) Corr: 1.000(Min: 0.900) Thd: 0.316(Max: 1.000) DC:-0.000(Max: 0.200) PASS
Center/Sub..(1)
L: Levl: 0.023(Min: 0.016) Corr: 1.000(Min: 0.900) Thd: 0.000(Max: 1.000) DC:-0.000(Max: 0.200)
R: Levl: 0.023(Min: 0.016) Corr: 0.999(Min: 0.900) Thd: 0.000(Max: 1.000) DC:-0.000(Max: 0.200) PASS
CWGMSG_SUCCESS
Line In.....(0)
L: Levl: 0.140(Min: 0.055) Corr: 1.000(Min: 0.900) Thd: 0.131(Max: 1.000) DC:-0.000(Max: 0.200)
R: Levl: 0.000(Min: 0.055) Corr: 0.008(Min: 0.900) Thd: 0.061(Max: 1.000) DC:-0.000(Max: 0.200) LEVEL FAIL
FAIL
Aux.........(0)
L: Levl: 0.047(Min: 0.015) Corr: 1.000(Min: 0.900) Thd: 0.099(Max: 1.000) DC:-0.000(Max: 0.200)
R: Levl: 0.000(Min: 0.015) Corr: 0.042(Min: 0.900) Thd: 0.099(Max: 1.000) DC:-0.000(Max: 0.200) LEVEL FAIL
FAIL
CD..........(0)
L: Levl: 0.157(Min: 0.070) Corr: 1.000(Min: 0.900) Thd: 0.561(Max: 1.000) DC:-0.000(Max: 0.200)
R: Levl: 0.001(Min: 0.070) Corr: 0.038(Min: 0.900) Thd: 0.516(Max: 1.000) DC: 0.000(Max: 0.200) LEVEL FAIL
FAIL
Stereo Mix..(0)
L: Levl: 0.196(Min: 0.155) Corr: 1.000(Min: 0.900) Thd: 0.105(Max: 0.700) DC:-0.000(Max: 0.200)
R: Levl: 0.200(Min: 0.155) Corr: 1.000(Min: 0.900) Thd: 0.144(Max: 0.700) DC:-0.000(Max: 0.200) PASS
Mic.........(0)
R: Levl: 0.000(Min: 0.001) Corr: 0.105(Min: 0.900) Thd: 0.000(Max: 1.000) DC: 0.000(Max: 0.200) LEVEL FAIL
FAIL
Mic.w/Boost.(0)
R: Levl: 0.000(Min: 0.030) Corr: 0.098(Min: 0.900) Thd: 0.165(Max: 1.000) DC: 0.000(Max: 0.200) LEVEL FAIL
FAIL
Tad.........(0)
Line In.....(1)
L: Levl: 0.139(Min: 0.055) Corr: 1.000(Min: 0.900) Thd: 0.104(Max: 1.000) DC:-0.000(Max: 0.200)
R: Levl: 0.140(Min: 0.055) Corr: 0.999(Min: 0.900) Thd: 0.116(Max: 1.000) DC: 0.000(Max: 0.200) PASS
Aux.........(1)
L: Levl: 0.047(Min: 0.015) Corr: 1.000(Min: 0.900) Thd: 0.108(Max: 1.000) DC: 0.000(Max: 0.200)
R: Levl: 0.047(Min: 0.015) Corr: 0.999(Min: 0.900) Thd: 0.105(Max: 1.000) DC:-0.000(Max: 0.200) PASS
CD..........(1)
L: Levl: 0.156(Min: 0.070) Corr: 1.000(Min: 0.900) Thd: 0.566(Max: 1.000) DC: 0.000(Max: 0.200)
R: Levl: 0.158(Min: 0.070) Corr: 0.999(Min: 0.900) Thd: 0.596(Max: 1.000) DC: 0.000(Max: 0.200) PASS
Stereo Mix..(1)
L: Levl: 0.194(Min: 0.155) Corr: 1.000(Min: 0.900) Thd: 0.081(Max: 0.700) DC:-0.000(Max: 0.200)
R: Levl: 0.198(Min: 0.155) Corr: 1.000(Min: 0.900) Thd: 0.080(Max: 0.700) DC:-0.000(Max: 0.200) PASS
Mic.........(1)
R: Levl: 0.069(Min: 0.001) Corr: 1.000(Min: 0.900) Thd: 0.007(Max: 1.000) DC:-0.000(Max: 0.200) PASS
Mic.w/Boost.(1)
R: Levl: 0.344(Min: 0.030) Corr: 1.000(Min: 0.900) Thd: 0.556(Max: 1.000) DC: 0.000(Max: 0.200) PASS
Center/Sub..(1)
L: Levl: 0.042(Min: 0.016) Corr: 1.000(Min: 0.900) Thd: 0.000(Max: 1.000) DC: 0.000(Max: 0.200)
R: Levl: 0.043(Min: 0.016) Corr: 0.999(Min: 0.900) Thd: 0.000(Max: 1.000) DC:-0.000(Max: 0.200) PASS
Software Configuration Test
Wave Output Drivers Test
1: Microsoft Sound Mapper:
Testing 44kHz stereo 16 bit: Device was opened successfully.
2: Santa Cruz(tm):
Test 3: Check Wave Out Drivers Pass
Wave Input Drivers Test
2: Santa Cruz(tm):
Test 5: Check Wave In Drivers Pass
MIDI Output Drivers Test
1: Microsoft MIDI Mapper : Device was opened successfully.
2: Santa Cruz DLS Synth : Device was opened successfully.
3: Santa Cruz(tm) : Device was opened successfully.
4: Santa Cruz External MIDI : Device was opened successfully.
Test 2: Check MIDI Out Drivers Pass
MIDI Input Drivers Test
1: Santa Cruz External MIDI : Device was opened successfully.
Test 4: Check Midi In Drivers Pass
Mixer Drivers Test
1: Santa Cruz(tm) : Device was opened successfully.
Test 6: Check Mixer Drivers Pass
DirectSound Test
DirectSound Playback Devices
->Primary Sound Driver
->Santa Cruz(tm) (tbcwdm.sys) {BD6DD71A-3DEB-11D1-B171-00C04FC20000}
DirectSound Capture Devices
->Primary Sound Capture Driver
->Santa Cruz(tm) (tbcwdm.sys) {BD6DD71B-3DEB-11D1-B171-00C04FC20000}
Test 8: Check DirectSound Drivers Pass
What happens is sound only comes out of the front left and center speakers. The sub works as well. No sound comes from my rear or front right speaker. There are also audible snaps and pops like underlying static that I never used to get with my audigy 2. My audigy 2 sounded great with these speakers. I'm using the logitech 5.1 z-640s. Should I RMA the card or is there something that I can do to fix it?
08/19/04 18:24:26
Windows 5.1.2600 NT
Hardware Test
CWGMSG_SUCCESS
CWGMSG_SUCCESS
Line In.....(0)
FAIL
Aux.........(0)
FAIL
CD..........(0)
FAIL
Stereo Mix..(0)
Mic.........(0)
FAIL
Mic.w/Boost.(0)
FAIL
Tad.........(0)
Line In.....(1)
Aux.........(1)
CD..........(1)
Stereo Mix..(1)
Mic.........(1)
Mic.w/Boost.(1)
Center/Sub..(1)
CWGMSG_SUCCESS
Line In.....(0)
FAIL
Aux.........(0)
FAIL
CD..........(0)
FAIL
Stereo Mix..(0)
Mic.........(0)
FAIL
Mic.w/Boost.(0)
FAIL
Tad.........(0)
Line In.....(1)
Aux.........(1)
CD..........(1)
Stereo Mix..(1)
Mic.........(1)
Mic.w/Boost.(1)
Center/Sub..(1)
2: Santa Cruz(tm):
2: Santa Cruz(tm):
Mixer Drivers Test
DirectSound Test
