- Jul 13, 2012
- South Wales, UK
Hi guys,
Here's my first post on here
first off, my specs:
Mobo: ASUS M4A78LT-M LE
CPU: AMD Athlon II X2
RAM: 2GiB
GPU: VTX Radeon HD 5450
OS: Ubuntu 12.04 LTS
OK, got that out of the way here's my problem:
As you can see above I my GPU should be a Radeon 5450, but after I fresh installed 12.04, things started going wrong. First of all I had to actually re-install the OS twice after I tried installing Catalyst Control Centre, which then left me booting up till the Splash screen.
After that I didn't bother trying to reinstall the official drivers, until now, only I know that it will end up breaking my OS again, so I did some digging in the terminal giving Ubuntu this command:
Which came out with this:
Now that can't be right, to me it telling me that I have a Mobility Radeon HD 5430, so I found another command to try to back up what this one said:
Came out with this:
OK so Ubuntu thinks I have a completely different GPU to the one I have bought.
I did some digging into that card to find it's a Netbook/Laptop card, and I'm running on a Desktop so this can't be right at all.
Here's my question.
How do I tell Ubuntu I'm using the 5450 and not the 5430? Or how do I configure Ubuntu to use the 5450?
Thanks.
Jamie.
RAM: 2GiB
Code:
sudo lshw -C video
Code:
*-display
description: VGA compatible controller
product: Manhattan [Mobility Radeon HD 5430 Series]
vendor: Hynix Semiconductor (Hyundai Electronics)
physical id: 0
bus info: pci@0000:01:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
configuration: driver=radeon latency=0
resources: irq:42 memory:d0000000-dfffffff memory:feae0000-feafffff ioport:d000(size=256) memory:feac0000-feadffff
Code:
lspci | more
Came out with this:
Code:
01:00.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI Manhatta
Here's my question.
Thanks.
Jamie.
