- Oct 21, 2012
Hey evreyone,
I recently built a new computer with a Gigabyte z77x UD3H motherboard and got it up and running and installed windows 7 and could enter BIOS.
A few days ago I installed an h100 cooler and I am now unable to enter BIOS and it will not boot. When i turn the computer on, all the fans and light turn on and the motherboard cycles through a few codes and the Gigabyte splash screen shows for a bit but when I press DELETE to enter the BIOS the screen just stays blank. When I let the computer try to boot the screen also stays blank after it shown the Gigabyte splash screen
Ive cleared the cmos with the jumpers, the button, and took the battery out with the computer off and unpluged. Also, when i turn the computer and just let it run, I am getting an A9 error code that will not go away. The A9 errore code is "Bios has started." The code will stay there until I turn the computer off though.
I do not have a GPU connected.
The only things c0onnected to the motherboard are the fans, 24 pin, 8 pin CPU, and ive tried with the hard drive both connected and disconected.
Does anyone know what the problem may be or what else I can try to fix this?
