- Aug 17, 2002
Hi all,
Basically, the problem is: I have a server, which acts as a webserver, printserver, etc. The onld one i had was just a basic dell workstation, 400Mhz / 256 ram / 60GB hard drive.
However, I bought an upgraded one: a P4 1.6 / 320 and I thought: I'll just move the old hard drive straight across to the new machine.
However, in short, Windows doesn't like this. It always Bluescreened on startup and wouldn't boot. I assumed this was because it was finding that the installed drivers (for the P2 400) were different from this new machine.
Installing a new hard drive and installing windows fresh onto it worked fine, however. The problem is though, losing this data / reformatting is not an option, since i'd never be able to get the server reconfigured like it was.
I now have a backup of the data on another hard drive (which seems to be half way through a windows installation, but won't work on the new system either way) and I keep moving it between the two systems, in the 400 as a secondary disk to move files and back forth, and a bootable one on the 1.6.
I've tried many different things, all to no avail: Taking all the drivers from a newly installed disk on the 1.6 and overwriting the backup OS with them, just deleting drivers, etc.
I believe that the windows XP feature on the disk that deletes and rewrites all the system files may fix it, but as far I have not been able to invoke it (It only appear on the windows bootup installer if certain system files are missing or something, and I haven't been able to make it appear).
Any idea how to make this restre option available for the windows boot disk? (Not "Automated system recovery" that requires a floppy disk (in the file loading stage) and not recovery console: the other, automated one)
or any other general ideas how to fix this?
Please help ^_^;;;;
Thanks,
Arby
Please help ^_^;;;;
Thanks,
Arby
