- Jun 6, 2002
after some thought and suggestions to people on another forum. i set out to make the cheapest oced rig possbile, ocing maxmizes the price/performance of your setup. what did i come up with you ask...
CPU
$59.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116064
or
$84.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116052
Motherboard $49.99,support for the 45nm dual cores
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157119
Ram well this will be where you choose.
start with 2 gigs$44.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145015
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231119
want 4gigs $94.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231120
Video card $104.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102725
Psu $89.99 w/MIR for $59.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371007
case $39.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119149
DVD $31.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827129009
E1200 w/2gig = $422 w/mir = $392
E1200 w/4gig = $472 w/mir = $472
E2180 w/2gig = $447 w/mir = $417
E2180 w/4gig = $497 w/mir = $467
but wait you say you said ocing but this doesnt look like a ocing setup to me.. thats where this comes in
http://www.ocforums.com/showthread.php?t=499340
the pad mod fools the motherboard into thinking its a faster fsb cpu. what does this mean with the 2 cpus above, simply this. the E1200 is stock 1.6ghz that would then become a 2.66ghz dual core for $60. with the E2180 stock speed of 2ghz you have the ability to turn it into a 3.33ghz cpu. though i have my doughts at the monent since i havent used the E2180 yet to run that speed at stock voltage. you could use the other pad mod on the cpu to make it a 2.66ghz cpu instead. that is if you think the extra 512kb L2 for 1mb is worth it over the E1200.
**** you will have to excuse some of it as i posted it for one of my gaming clans. they are not much onto ocing like we are here. after looking more into that board it does have ocing features in bios you can if wanted avoid the pad mod. as noted in the manual the board when running a 1333fsb cpu has the pcie oced to 115. it states both pci/pcie speeds to be locked but does not indicate at what speed the pci buss is running.
CPU
$59.99
or
$84.99
or
want 4gigs $94.99
Video card $104.99
case $39.99
DVD $31.99
