it is not a myth as i have proven hundreds of times. even though a system reaches equilibrium if you put a thermo right before your rad and right after you will see a diference and that should situate 1 thermo between your rad and cpu. if you put a third thermo after the cp you will see that its hotter than its input by more than 1C especially in games.RB, needing to cool the water before it enters your blocks is an old myth
Perseus said:I'm a sap for clean wiring. What can I say?
What are your temps and what blocks do you use? I almost popped for a Polarflo TT last time because of its flow characteristics, but I just HAD to try a Storm.
Vrykyl said:sumka isnt that d4 pump pulling water out of the cpu block and into the rad? should it not flow the other way?
Oh! I didn't mean to imply that you hadn't read the title or that you were implying or infering anything about what was worthy of discussion. I was just trying to be clear about why I brought it up lest someone get the idea that they absolutey had to have a double pass rad to keep their cpu from melting a hole in the floor.Perseus said:I did, BTW, read the thread title before deciding to participate. I didn't imply or infer that the laminar effect wasn't worth discussion.
I don't doubt you performed this experiment, but if your data is accurate, I don't understand the physics.thorilan said:it is not a myth as i have proven hundreds of times. even though a system reaches equilibrium if you put a thermo right before your rad and right after you will see a diference and that should situate 1 thermo between your rad and cpu. if you put a third thermo after the cp you will see that its hotter than its input by more than 1C especially in games.
No. 0.48C is how much the coolant temperature rises as it flows through the CPU block. It will be less confusing if you think about the water removing BTU's or watts from the CPU block instead of degrees.Dice said:Using That logic, the watercooling loop would only remove .48c from the 125 watt CPU.
Huh? If you add heat to liquid water, the water temperature goes up. The only exception to this occurs at the boiling point, and if your loop is running that hot, you've got far worse problems than the order of your components.There is the flaw. The water will hold more heat than its actual temperature would suggest and it is that heat, the unmeasured heat, that the radiator is removing before the water gets to the CPU block.
Otter said:Oh! I didn't mean to imply that you hadn't read the title or that you were implying or infering anything about what was worthy of discussion.
Otter said:No. 0.48C is how much the coolant temperature rises as it flows through the CPU block. It will be less confusing if you think about the water removing BTU's or watts from the CPU block instead of degrees.
HAH, is this considered a flame at Dan?Dice said:... and suggesting her equipment may be faulty.
TreeNode said:HAH, is this considered a flame at Dan?
greenmaji said:Or refering to Dan's rig as a woman, much like alot of guys do their cars
Dice said:Nice try at saving me, but I ate foot on that one.
That's a good point. I didn't include the antifreeze, but I know Thorilan uses 5% or less in most of his rigs, hence my numbers will be close. They might be 3% low, but the measured value shouldn't be twice what I calculated.Dice said:You are probably correct. It would be less confusing. While I concede that you are far smarter than I, I don't see your math accounting for these constants and variables:
~Specific gravity of distilled water (90% by volume) + Liquid Ethyl Glycol additive (10% by volume) as is accepted practice.
The specific heat and thermal capacity of water are included in the definition of a BTU. Again, Thorilan is savvy enough to know that antifreeze can't compete with water as a coolant, and his experience gives him the confidence to use as little as possible. Do a search of his posts with antifreeze as a keyword and you'll see he often points out that people use too much antifreeze in their systems.~Specific heat of both of the above.
~Thermal capacity of both of the above.
Not enough to matter. Pure water is only .43% less dense at 30C than it is at 4C. Hence we can neglect the effect of temperature on the thermal capacity of water for estimates like this.~Temperatures of coolant samples. (Which, as I am sure you know, affect the thermal capacity of the coolant.)
I also suggested my understanding might be faulty. As the two don't agree, at least one of them has to be off. But there is no fight here.I only say this because you are using your math and physics against Thorilan's thermometers, and suggesting his equipment may be faulty.
That's why I said it would be less confusing if you considered BTU's (heat) or watts (heat/time) instead of degrees. Celsius degrees are units of temperature, not heat. What's a water unit?Dice said:With a 1:1 ratio of heat units to water units? That still doesn't account for the thermal capacity, does it?Otter said:Huh? If you add heat to liquid water, the water temperature goes up. The only exception to this occurs at the boiling point, and if your loop is running that hot, you've got far worse problems than the order of your components.
In hindsight, I can see how it might seem that way. But when I wrote the post, that was the furthest thing from my mind. And because I wasn't thinking it or saying it, it didn't occur to me to be diplomatic about it. No offense intended.Perseus said:It sure seemed like it, but okay.
True. But we'd just been talking about how these small differences in performance can take on exaggerated importance for someone still absorbing the basic concepts. See where I was coming from now? Though it was part of a reply to you, the bit about the thread title was intended as a general comment rather than a reference to anything you'd said.Perseus said:Otter said:I was just trying to be clear about why I brought it up lest someone get the idea that they absolutey had to have a double pass rad to keep their cpu from melting a hole in the floor.
I doubt there was any real danger of that happening. It isn't too hard to understand that there are tradeoffs associated with differing design methodologies.
Hmmm. 2C better than what? Do you have enough data to separate the effect of other things, like having the pump at the bottom of the loop, from having the GPU between the rad and CPU?thorilan said:and what i have seen is that the way i do it i see about 2c better temps at load and they drop faster when load is reduced .
