System -
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128503&Tpk=gigabyte z68mx b3
OCZ agility 3 ssd
windows 7 home prem
Every so often, usually between 6 hours and 3 days I will get a shut down. It only occurs when playing everquest 2, so obviously this could be an issue. But it is not like I am in windows that long at a time either so it is hard to use that as a reference point. Event viewer really does not show anything helpful before the crash, just the power issue after (from me shutting it down).
What happens is as follows - the game itself freezes, but vent in the background is still working and audible, although my keyboard does not work. I can hear others and my mouse still moves and when i alt tab i revert back to the windows mouse instead of the image of the game mouse, but can't do anything (num lock caps lock dont work). Eventually the computer locks up, but in and of itself it does not shut down. I have to reset it or power it off manually.
The system is stable in prime 95 at 4.3 ghz and stock voltages with the only settings changed as follows - power states all disabled ie c1 eist etc. p95 was stable for about 26 hours then i turned it off. Ran blend tests. memtest86+ is stable for around 3 hours and I turned it off.
** One weird thing, if I oc then memtest shows a lower memory speed because it slows my bclck down. IE at 3.3 ghz it shows 1600 speed at 100 bclck but at say, 4.5 ghz it shows around 1176 speed at 73 bclk. Is this a usual change?
Anyway, I am going to run it at 3.3 ghz and play and see if I can mimic the issue thereby narrowing it down. But, that being said, I wanted to get advice / opinions here as soon as possible and i will edit shortly. off to work ~
Oh and anyone with this MB if they can help with settings i would appreciate it. I will try and post the options soon to get some advice.
thanks as always
edit - to add a few things which may or may not be relevant.
Heat isnt an issue. its WC and in an ~70 degree F room real temp never shows above 59 F.
one time I THINK i hit shut down and the computer did a restart. i cant be positive though, but hitting shut down and having a restrart would lead me to think a possible MB issue. this would have been with the f2 bios, it has not reoccured with f5.
i use the latest radeon 6950 driver but dont use control center. never seemed to have a need.
It just feels like a memory, GPU or HD issue. I have nothing to back that up but when i have had CPU OC issues in the past they have been full halts, whereas this seems to be more a failure somewhere else in the chain. again, i have nothing to back this up other than past events and a feeling.
I suppose my biggest hurdle now is to figure out what programs / utilities i can use to narrow down the problem piece of hardware / software. I dont have any spare hardware to switch out for testing =(
I was thinking of lowering the mem speed to 1333 from 1600 and messing with the timings. The only ram voltage option i have is dram voltage and its running at stock of 1.5v. Speaking of voltages, no matter what i do, cpu-z tells me the vcore is 1.068v. In the BIOS if i change vcore it shows a change in the bios but not cpu-z. like i said though, for now vcore is on auto. Why is this? an issue between my mb and the cpu-z program?
Sorry everything is not really organized, I am at work throwing everything i can think of out there to help with troubleshooting. im usually quite OCD about my grammar and sentence / paragraph structure lol.
I will update as stress tests are done in sequence for 24+ hrs over the next week if i cant solve it / find help sooner here ty
OCZ agility 3 ssd
windows 7 home prem
thanks as always
