Well just tried overclocking my old 955be and i could not get it stable on this board, not even stock. Where i could get it stable on my old asus m5a78l. Wich has a 3+1 VRM. Im starting to wonder if this board is just not okay. Or if there is something else going on....
S_C there is no way to really know if there is something else going on. Why?
1.) Well we don't have the board close to hand to really set at the keyboard and adjust closely everything to see what is what.
2.) There seems to be a pattern where the later bioses that are being assembled for FX cpus mayNoT work so well for Phenom2 type cpus.
3.) IF the board is AM3+ and in a later revision or is built when the FX cpus have just about taken over like the GA-970A-UD3P board was released...then they don't work well with Phenom2 type cpus.
4.) A board that was built heavy duty from the very first one that was released 2.5 years ago as AM3+ will likely have an early bios that can be flashed onto the board and work probably better for earlier AMD Phenom2 type cpus. But when swapped back to an FX type cpu would need to be flashed back to a later bios.
Motherboards like the 970 Extreme4 have not been recommended by most of us that help in this forum section in at least 2 years because they just were not heavy duty enough to push 8 core FX processors AS FAST as a good FX 8 core processor would go. So we don't have much of a baseline as to how those boards 'might' operate on earlier cpus just because most have bought better boards and ALSO bought to go with FX processors and for that we would not be recommending the 970 Extreme4 anyway.
So you and the 970 Extreme4 maybe in a time warp. You could be using a bios not really well suited to Phenom2 cpus or just that the board is not well setup to run the Phenom2 cpu you installed for a quick test. You would really have had to spend a great deal of time with these AMD boards and FX processors and the like to see these types of trends develop. Take the Sabertooth 990FX R2.0 that you are buying that has been for sale in that Revision for a pretty long while now, and most of the guys in here that you see put up the big numbers, don't even run the later bioses on their boards with FX processors. The older bioses often just seem to work better for heavy overclocking and all of US do that deed.
It really is not very complicated but it does require a little extra or make that a better working knowledge of what has transpired over the last 2.5 years as the FX processor has taken hold in a big way. Certain parameters have changed in how the bioses work when the FX processor and even Win 8 came on the scene and later boards have certainly been slanted at the FX processor and in that situation, every board can generally run a later FX processor but not every later board is suited to pushing and hitting on it to run an FX processor to try and clock it up high enough to 'try' and catch up with an Intel processor.
I would not believe that the Sabetooth 990FX R2.0 would overclock a Phenom2 processor with the very latest bios as well as with an older or first release bios for the R2.0 board. Seems just a fact of life in how the bioses are being tweaked for the cpu of the age.
RGone...
