Not sure I understand your LLC options. Most motherboards have have something like: Disabled, 1, 2, 3, 4, 5, 6, 7. Some others will only have: Disabled, 1, 2, 3, 4, 5 or in other words, bigger steps with less granularity.
The idea behind LLC is to add a supplement to the core voltage under load so that it brings it back up to the level you have nominally set it to in bios. In your case, you would need to experiment with the different levels of LLC to find the one that comes closest to restoring the vcore to what you set it to in bios.
1.25 vcore may simply not be enough to make the system stable at 3.6 ghz so try more voltage. Having said that, that motherboard does not have a strong VRM (Voltage Regulation Module) and it may not be up to much of an overclock. Read this thread:
https://www.overclock.net/forum/11-...7-amd-motherboards-vrm-info-database-139.html The eight core FX CPUs pull tremendous amounts of power when overclocked.
Also, what are you cooling the CPU with? Are you monitoring core/package temps when you stress test with something like HWMonitor? Is the problem really that you are exceeding the temp threshold of stability. The FX CPUs would only handle about 55-60c core/package temp before becoming unstable.
