- Jul 15, 2014
Is my Sig okay now guys?
Yessir much better
Yeah mine doesn't, so was gonna have the fan at the top blowing it down to the bottom....
Yea that is how my 212 evo is
Shall I just put it like that then?
We'll with that being the case find someone that has some ram the doesn't sit as high. I know the other day I seen a thread that had a few different ones for a decent price. Not sure the speed or size though.
If it had good contact with the CPU beforehand go with that in my opinion. If you are still having cooling issues swap ram with shorter sticks to make sure you have good contact.
Yes that's much better JethroJay, I had a look at all your parts and I see that cooler won't turn front to back with AMD, which my revision 1 did. Like Ray says if you can return that ram and get some low profile stuff you'd be further ahead in the cooling department. If the cooler hangs up on the ram you can't get good contact with the CPU so heat is not being transfered to the Heatsink.
If that's not a typo and you're really hitting 78c then there's still a problem . You don't want the core temp over 60 for any real length of time.
Exactly how high are your temps getting under load? Like Johan said hopefully not 78.
A lot better than where you started out at.
