Hi,
I have a problem with an older Intel system, socket 1156 with a Xeon processor in installing windows 10.
I'll try to keep this as simple as possible.
System is still in good working order because it has been stress tested with p95 blend for several hrs @ stock settings in the 1607 version with no issues whatsoever, because it was in storage for 6+ yrs. Also the SSD has been chkdsk with /r switch & all good.
First install was done with 2016 retail USB key, hence the 1607 version. I tried to do the install from the latest 1903 version with a bootable DVD, but I get to the point of seeing the windows icon on screen & can hear the optical drive ( a new unit) loading the files, then it gets to the end of this (green LED on optical drive no longer indicating action) & system locks up. That is the numlock key on keyboard is frozen & see no spinning wheel dots that you usually see when windows loads in it's usual form (hope you know what I mean).
I have investigated this problem on the MS site & they suggested running the update assistant. I did this, it goes through it's thing, get it to reboot & the old problem is back again - that is, the loading of the windows icon & then freezes!
Investigating this further & MS recommended the "wu10" tool to fix update problems, so once again... go through the process, it does it's thing & informs me several problems are identified, so I get it to fix this of course.
All good it then reports...
As I'm typing this, the machine on another desk is downloading 1809.... AGAIN! it'd done this b4, says it needs a reboot to finalise the install & then... back to the old problem AGAIN of a corrupted install because of the freezing system when the windows logo is the only item on the screen....
Rebooting, it goes on as normal, log in & a check of the version reveals 1607...
I have also disconnected unnecessary devices & only have devices for basic functionality ie.. Keyboard with PS/2 connection & one USB mouse, nothing else but the monitor of course.
Also have another old AM3 system that got installed with 1903 version from the same bootable DVD I mentioned earlier in this post & it went fine, all working well. So I know my install DVD is not mucked up & working properly.
Any helpful advice on this challenging problem would be most appreciated & sorry for the long post but hope the scenario makes sense.
