I appreciate everyone's help here with all the OC and suggestions and everything that this community has done to guide me through trying to get my computer OC'd and all the advice about how my CPU was bottle-necking my GPU marginally etc.
I have decided (Since I have about a 550-600 saved aside for upgrades already) to just make the upgrade since my Geforce 280 saying my q6600 @ 3.0ghz is holding it back. (Plus I couldn't get it stable above 3.0 and I've read post after post here about the older q6600's being bad with overclocking )
My current rig:
Full Tower Case by ULTRA forgot model..
XFX Nforce 680i LT Mobo
Intel Core 2 Quad Q6600 @ 2.4 ghz (stock)
6GB OCZ DDR2 800mhz Memory
Western Digital WDC 500gb HD (data/games/etc. - don't remember speed but I got it a long time ago 2-3 yrs...)
OCZ Vert 64gb SSD HD (operating system)
NVIDIA GeForce GTX 280 1gb superclocked
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
750w power supply
The parts I am looking to upgrade to:
Hard Drive (Just because I need more space) - these are the same, just different sizes right?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4034139&CatId=2459
or
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4538820&CatId=2459
CPU
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4089666&CatId=2758
(Might upgrade Mobo + RAM if will work better with this CPU choice)
Mobo
http://www.tigerdirect.com/applicat...details.asp?EdpNo=4394541&csid=ITD&body=MAIN#
RAM
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3984931&CatId=3361
Please post any suggestions,thoughts, or advice on parts that you would suggest to use instead of these. Basically, tear my system apart and tell me the best parts I could go for with my $550-$600 budget.
Question:
-The CPU I chose, is it overclockable? (I've read a lot of bad on OC'in my current q6600, want to make sure I don't get something I can't OC if I want to)
-Does my Mobo have anything to do with how well I can OC that CPU? If yes I will probably buy that mobo I linked..
-Will upgrading to that CPU + Mobo(supports ddr3) + ddr3 memory provide enough performance increase to justify the price of upgrading to dd3 ram as well?
-Should I go to the i5/i7/ddr3 ram/new mobo or will this be the best choice of upgrades to do for a $550-600 budget?
-Will I notice substantial enough performance boost (since everyone here says my Q6600 bottlenecks my GPU hard) by switching to this CPU?
I know it's a lot to read and I have a lot of questions, but I want some knowledgeable feedback and advice before I drop this much money >_<
My current rig:
750w power supply
or
CPU
Mobo
RAM
Question:
