Theres alot I need help with so ill get right to it:
Im interested in the gaming aspect of my pc. I bought my parts before I really knew anything about overclocking and since overclocking is a good way to save cash thats the route im looking towards. Here is the current setup:
Intel Pentium D 820 2.8 ghz dual core
MSI P4N Diamond Motherboard
2x Corsair Value Select 1 Gb DDR2 533 memory (2gb total)
XFX 7800 GTX 256Mb Nvidia Graphics Card
Antec TP2-550W Power supply
ZALMAN CNPS 120mm Copper LED CPU Cooler
Right away many of you who know will notice that the Pentium D 820 can only run in single core what seems like any board that supports SLI.
Hence the problem: My grand plan is to one day get another 7800 GTX and have an SLI system. These parts came from when I thought I knew about computers but actually didnt know jack.
Ive learned alot the past 8 months or so and the most important thing ive learned is that no matter how much I think I know, without asking experts Ill always screw something up.
Im leaning towards selling the Pentium and getting one that actually works with this motherboard and overclocking it. However the more I learn the bigger the hole im stuck in seems to become.
So heres the things I need addressed:
* Ive heard that all current intel compatible SLI MB's are junk. Is this true? I really like the P4N Diamond and havent had any problems with it.
* I also know that when it comes to gaming AMD performs better in most comparisions. Should I bite the bullet and switch to AMD before its too late?
* If I stick with intel, should I buy a good processor and try to get a small overclock on air, or buy a lesser processor and water cooling for a bigger overclock? (I have about $400 dollars to spend in this catagory, and I think I would be really content with hitting 3.8-4ghz while spending the smallest amount possible so the rest can go towards other computer issues)
* What air or water solutions would allow me to get a good overclock? With my current cooling my CPU runs at 40C idle and around 50C load which already seems high.
* What processor/processor speed would I need to take full advantage of dual 7800 gtx's?
* Should I go with a dual core cpu or a single cpu for overclocking/gaming? Ive heard dual cores will be important in the future but they also seem to run hotter which would make them more difficult to overclock. I know I have to get a new processor but Im still looking to save as much cash as possible so I can use the leftovers towards other parts.
I am open to ALL advice about anything related to my system. For example, if my RAM sucks for overclocking, please tell me why and what a better solution would be.
Basically I want to know what the ideal system for me would be and using my budget and my current parts get as close to it as possible. I wanna make any big changes now before I get any deeper into this hole so keep that in mind. I dont want to be kicking myself in 6 months saying "why didnt I switch to AMD when I had the chance." Please take some time to help me out. Thanks
