- Jan 12, 2013
- Colorado Springs, CO, USA, Earth
I got an HP Pavilion G6 2233-nr notebook PC with Windows 7 64-bit installed. It came with 4GB of RAM. Recently I bought another 4GB RAM card and added it into the second slot, and since, the computer has been much slower. Starting it up takes considerably longer, opening up a program takes a very long time, so on. Though what is weird is that the ADDITIONAL time I open up a program, it opens up lightning fast, as fast as it should. It's just the first time I open up a program after I boot up the computer, it takes forever, much longer than it originally did.
I don't really know why this is. Yes, it's the exact same model, COMPLETELY identical to the original stick of RAM I had in. Speccy is showing it is running in Dual-Channel @ 665MHz (9-9-9-24). It is also detecting that they are the same exact model. I ran the Windows Memory Diagnostic tool and it returned no issues. Apparently both modules are working just fine.
What's weird is that I even tried taking out a stick, and even with just the original one in, it's still slow. Way slower than when I didn't install more RAM to begin with. Yes, I tried switching the cards around and only using one of each, I flashed the BIOS to the latest version, reinstalled WiFi and GPU drivers, etc.
What is the problem here?
