- Mar 13, 2011
- Chaparral, New Mexico
I purchased a used 1080ti from ebay, worried that it was a mining card I wanted to run 3dmark to get an idea if it is performing as it should. Leaving the argument whether the degradation is an issue or not aside.
GPU-Z states the card is running at 8x, which also shouldn't be a problem I know. I have it on the lower slot which I believe is suppose to be a 16x slot, have a nvme ssd in the slot next to it as well. Wont fit into the top slot without trimming the fan shroud as it hits my water res.
System:
Asus z370 a prime
8700k @4800mhz
2x8gb @ 3200mhz
Gigabyte Aorus 1080ti
All stock with fresh driver install graphics score 9829, cpu 8957, combined 9687.
Power limit and temp limit maxed core got to 1962 and stayed there. Graphics score 10,188 , cpu 8846, combined 9961.
Combined scores of others with same hardware 10,500+
Not sure if it's normal or if something is wrong. The used gpu is what's getting me. Thanks
System:
Asus z370 a prime
8700k @4800mhz
2x8gb @ 3200mhz
