I just got the case a week ago and am in the process of installing my setup. I can say that this case is a watercooler's dream! I will snap a few pics tonight of what I have done so far. What I've done so far is: Remove all of the HD racks in the lower front of the case. Cut out a large square in the divider that seperates the lower front and the psu. I mounted a D-tek Procore shroud to the front 120mm fan, then the Procore, shroud, then a 120mm Panaflo to that, with the airflow blowing into the case. Between the rad and the divider, I put my new MCP-650 on a homemade aluminum stand, so the outlet of the rad is the same height as the intake of the pump. The pump is directly below the hole going to the upper part of the case.
Now I'm just waiting to transfer the rest of my stuff into the case. I have a new Epox NF3 939 board and cpu (3500+ 90nm) coming and I will transfer my silver TDX and Dangerden Bayres into it as well. I hate waiting around for stuff to come in the mail!
I'll post a pic tonight of my progress so far. I can say that there will be a whole lot of room, even with everything in it.
Shawn
