Hi there,
I am having trouble with VCore spikes for a while now and cannot figure out how to solve this issue. Would much appreciate your help! I already read many interesting posts in this forum and so I thought this might be the right place to ask.
My Hardware: GA-EX38-DS5 (BIOS version: F5B) + Q6600 (rev G0)
The Problem: VCore spikes (variations) make the system unstable. Lessened potential for overclocking.
What I observe: Say I set my CPU Voltage in the BIOS manually to 1.2250v and CPU clock to 320MHz. The actual idle VCore may then be 1.17v. However, once I put load on the CPU (e.g. small FFTs), it rockets to 1.30v (with high variations). See attachement "erratic". I assume that sudden load changes make the system unstable (because of voltage peeks).
What I want to know: How to permanently disable load-dependent VCore adjustments?
What I tried: I already read a lot about Loadline Calibration, EIST and C1E. As far as I understood, disabling all of them should answer my question. In fact, I did, and for some time, it did seem to work just fine (see attachment "stable"). However, for some reason unknown to me, after some time (havnt found a pattern yet), the system always seems to revert somehow to enable Loadline Calibration without me changing anything in the BIOS. I have not been able to disable the spikes since.
Best,
Matthias
Best,
Matthias
