System specs :
CPU: Core i5 760
MB: ASUS P7P55D
RAM: Corsair Vengeance 8GB Dual Channel 1866Mhz (9-10-9-27-1.5v)
GPU: GTX 670
OS: Windows7 Ultimate x64
MB BIOS: 2101
Problem: RAM becomes half (4GB) at 1.5v but using 1.65v solves the problem of available RAM but System is unstable worried about high voltage on 1.5v spec RAM.
Other Settings include
BCLK: 187 (to get RAMs to 1866Mhz)
Voltages:
IMC: 1.20 (to get to 187 bclk)
DRAM: 1.65
PLL: 1.8
LOC: disabled
Everything else is on AUTO
Manually setting SPD has no effect, Using XMP Profile makes only 4GB usable.
One thing I noticed is Round Trip Delay becomes zero below 1.65v for CH(A).
Another Question is what is more preferable; AUTO voltages or Manually specifying them. The board varies voltages in set to AUTO.
Memtest86+ gives zero error on 1 hour wall time. But that is at 1.65v.
Any help is appreciated, Thanks.
CPU: Core i5 760
MB: ASUS P7P55D
GPU: GTX 670
MB BIOS: 2101
Voltages:
DRAM: 1.65
PLL: 1.8
LOC: disabled
