Hello all! I'm building my first pc ever, and I need advice badly. I have just enough money now saved for my budget (2500) And my build is nearly right up to 2500. So I have the parts picked out have spent months researching it, I definitely would like someones opinion on what they think, before i actually buy them. I want to get it right. Keep in mind, I don't want to overclock yet, someday i might though so i gave my self the option, and i picked out a 1080p 60hz monitor which makes my gpu overkill, but thats okay because I want to play all games maxed out 60fps for a while, and eventually will upgrade to 1440p. Also, I should note that I plan on using my SSD for my OS and my steam account, which will hold games such as skyrim and the GTA series. So! Here's my full build, let me know what you think!
CPU- i7-4790k
MOBO- Asus Maximus Hero VII
GPU- MSI GTX 980ti 6GB
RAM- G-skill Ripjaws 16gb (8x8) 1600
SSD- Samsung PRO 512GB
HDD- WD BLACK 1TB
CASE- Phanteks Enthoo Luxe
PSU- EVGA 850w Gold Fully modular ATX
LG Optical drive
windows 10 64 bit
Asus MX279H 27.0" Monitor
Thanks for any tips! Anything I should add or change? Am buying next week so would appreciate any help!
CPU- i7-4790k
HDD- WD BLACK 1TB
LG Optical drive
windows 10 64 bit
