- Mar 3, 2003
- Toronto Canada
Hi guys,
Ive designed a new case for myself. Tried to make a 3d model (never done that before) of it before i will build it. This is something i will start to build (hopefully) early next year, as right now im moving from Montreal to Toronto with my fiance, and i need to find work, and settle down first. Tell me what you think:
Its made out of blue plexi glass (if it exists), except for the back, which will be a mesh type wall so air can travel through. The inspiration for this case is to have an enclosed computer, without the negative effects of having air trapped inside and warming up the system (like is currently happening to my present case).
I wanted air to enter, and exit as quickly as possible, and as efficently as possible, only cooling a few things before coming out.
Its hard to tell, but between the bottom and top section, i created a little space (between the bottom of the motherboard, and above the psu/hdd) so that it acts like a thermas, so heat from the bottom doesnt effect the stuff above.
Another thing i wanted to do is keep the case as small as possible, so the entire case is just wider then the motherboard, and just taller then my a thermalright 120 extreme on the motherboard.
The fans on the top section are 120mm fans, while the bottom fans are 92mm
