R. Williams
- May 19, 2018
I have rebuilt an old "Solid Stat Cooler" (Peltier unit) by installing two new 40mm modules (significantly larger than the original modules). I bench tested the completed unit using a 12v 12amp power supply and noted that, when the unit was operating, my meter read 11.2 v and the unit was drawing 10amps. It did not seem to be cooling or heating very much at all!
I disassembled the unit & metered both modules individually with the same findings. One full volt drop on each module! (slightly greater than 12v is recommended for optimal effect)
Am I missing something basic but important? Or should I be looking for a different vendor of TEC modules?
Thanks.
RW
Thanks.
RW
