4+2 phases are more than enough and shouldn't throttle under load at reasonable voltages. I have 4+2 phases on my current Z370 mobo and it runs 6 cores at 5GHz+ without issues.
Throttling is generally because of too high temps or too low power limit. Overheating VRM are not causing throttling, they are causing instability.
If you turn off all C states and other power saving options and set power limit higher ( not sure if your board has it but on some can set current limit to some impossible values ) then it shouldn't throttle but will shutdown once CPU is too hot and looking at some posts here, it's not overheating.
