- May 8, 2011
- Darlington, South Carolina
You really do not need high static pressure fans for a 10FPI radiator, that's why I chose the 4 x 180mm setup and 20mm Phobya shrouds, the noise level is very tolerable and the fans get the job done.
I am running 4 Silverstone but I am going to replace them with these 180mm Silverstone SST-AP182 Air Penetrators, as their speed can be varied from 500rpm to 2,000rpm as needed.
http://www.performance-pcs.com/silv...w-adustable-speed-control.html#Specifications
This would give you the best of both worlds extreme quiet when you need it that way and crank them up for gaming, I bought one of them to run on an Alphacool NexXxos Monsta 180 which has a core thickness around 75mm.
I was able to run the Silverstone at 1200rpm and it easily had a good airflow out the exhaust side and was still noise tolerable, but it does kinda get noticeable at 2,000rpm, still tolerable though.
Just consideration suggestions, OK, it's your build and your money.
One last thing FYI, the Watercool MO-RA3 to a certain extent could be used passively, some have done it, but not when overclocking!
