- May 30, 2010
Right, well as much as I'd hate to say it. I'm a noob... When it comes to water cooling.
That much being said though, I am in pursuit of my first WC box, and I just have so many questions still.. I've been plotting things out for the last few weeks, reading guides, comparing stats, reading reviews, but I'm really no closer to anything then when I started.
My setup is going to be as follows:
Antec 1200
- Asus Rampage III Ex-1366
- Intel Core i7 965 [Currently at stock speeds]
- EVGA 470 GTX Hydro FTW
- 6-24GB DDR3
- 2x 500GB WD HD's
- 1kW PSU [Pretty Generic]
I'm currently looking to W/C the CPU, the VCard, the RAM and the HD's, though I am not entirely against cooling the mobo as well given they have a single assembly for it now. Still seems like a sin to take off that sexy sink assembly though..
That comes the loop configuration, with as many parts as I'm going to be cooling, (And hopefully setting up for a later possible OC'ing) would a multi-parallel circuit be better suited, or a single, massive series line?
Forgive me for my lack of poorly drawn examples of loops, but what I was thinking was as such:
Tank -[1/2"]-> Pump -> 3-Way Splitter -[5/8"]-> (Pressure Valves) -> [(Mainboard)+CPU | GCard | RAM+HD] -> (Flow Meters) -> Combiner -[1/2"]-> 2-Way Splitter -[5/8"]-> Radiators -> Combiner -[1\2"]-> Tank
Albeit complex, a friend of mine who works with W/Cing occasionally said properly hooked up, and thoroughly leak-tested, this setup would theoretically be viable. One can't believe everything one hears however.
My dilemmas come in here though. After reading countless reviews and comparisons about the different radiators and setups, I still can't decide how many, what brand, what flowrate, and which configuration to go with. The cooling blocks and pump selection have me boggled down as well, but those are abit simpler to sort though.
My initial thought were a pair of 120.3 or 120.4 LF Koolances externally mounted to the case; but after my researching, I'm really just at a total loss. The KL's still look pretty good, but Thermochill PA120.3 .4's tend to strike more of an 'Epic' note from most of the sites I've referenced, but don't give flow optimization selections. And the MORA.9 Grid is just stupidly overpowered, by looking at temp delta charts..
I'm somewhat picky about noise levels, though I don't mind a bit of a hum, as I never take off my headsets except when I'm AFK. I still think this summarily disqualifies an array of Deltas though.
But yeah. This is where I sit. Please feel free to poke and pull at any part of the build, I'm in pretty desperate need of advice. XD;
Antec 1200
- 6-24GB DDR3
- 2x 500GB WD HD's
