Well I put windows 8 on my desktop just to see what it was like, I got in on the $15 upgrade and I gotta say it's not as horrible as I had imagined.
Between the usage of the full screen feature and a cleaner look I say it's worth getting used to, not to mention it's slightly snappier then 7.
Any interface change sucks because I like what i'm used to, but honestly I think I'll manage.
The start button hasn't left, it's just been re-skined and hidden. The corner where the start button used to be is now the spot that you can move your mouse and pull up a "full screen start menu". The same spot puts you back on the desktop, so it's not gone it just looks different and has some functionality that's tough to get used to.
I like the idea of connecting everything into the "start menu" but wish something like facebook was integrated properly as well as being able to have a google search button.
The overall look of it is much nicer and my animated background is gone but i'm sure stardock will come out with something.
pro: looks clean and full screen
con: hard to get used to (can't even shut down without several clicks or ctrl alt del)
conclusion: worth $15 and if I can't stand it i'll reinstall.
