Saying the Start Button has not left just been hidden is a bit disingenuous. The interface for that part of the UI has totally changed. It has been made into something that is not designed for a desktop UI rather a tablet/touchscreen.
Further this design philosophy is pretty evident in the rest of the UI. Making interacting with it via the standard keyboard/mouse setup annoying and inefficient. That they left the Taskbar but did not given an option to put the Start Button, and its old functionality, back shows their intent. This is not even as bad a change for change's sake. Rather it is MS forcing change on the market such that they can buy their way back into the cell/tablet market where they have fallen far behind.
And they are buying their way back into that market. That they are pricing Win8 so low is a clear indication of that. There is no way that such prices are indicative of the R&D costs for, mind you the 2 versions, Win8.
All that being said there indeed some incremental improvements to the OS 'under the hood'. To that point I say ok. That should be SOP, they win no points in my book for doing what they should be doing.
Now this is my opinion and that the OP, and anyone else, who feels the Win8 UI is 'not horrible' has every right to their own opinion. Further I am no stranger to UI changes given that I am old enough to have used computers when you learned CLI or did not use a computer. Then all of the graphical UIs over the years including early touch screen UI's via Palm and such. And so I have then to ask, why should we have to accept something as 'not horrible' vs something good?
Ok. Using the $30 upgrade. You are saying you can do a clean install using the key?
The process involved downloading the windows 8 compatibility program, buying the upgrade. downloading windows 8 and telling it to put it on a usb drive. How do you do a clean install when it tries to find a previous qualified OS before it will even install. I am speaking of a legal install....if you have to do something not so legal to use the upgrade key. I am not sure I want to do that.
On the upgrade, windows 8 leaves a nasty folder called windows.old which takes up a lot of valuable SSD space so does anyone know if that folder can be deleted?
I installed windows 8 again last night, because i wanted to try start8
Its ok after you install start8
I end up uninstalling and putting windows 7 back because this is nothing more then a windows 7 2.0 tablet os. why do i need all those blocks on a 30'' IPS monitor. so ugly
when i tried to do a backup image like how 7 is, its not easy... win8 is a step back for me in alot of ways
- Storage Spaces, really!
- File History, are you saying I cant see a file history in win7?
- Faster boot, not really if you're running a SSD
- Windows To Go, google does this
- Windows Live Syncing, google does this
- Improved Task Manager, normal users like my grandmother would care less
- Improved File Explorer, its ok
- Detailed File Copying, 50% of copying only takes 10 sec, whats the big deal
- Recovery Options (Refresh & Reset) you can do the same in windows 7
...all pretty huge features in Windows 8, or you can continue to pretend this is the same OS with a new modern UI slapped over the top.
Well I put windows 8 on my desktop just to see what it was like, I got in on the $15 upgrade and I gotta say it's not as horrible as I had imagined.
Between the usage of the full screen feature and a cleaner look I say it's worth getting used to, not to mention it's slightly snappier then 7.
Any interface change sucks because I like what i'm used to, but honestly I think I'll manage.
The start button hasn't left, it's just been re-skined and hidden. The corner where the start button used to be is now the spot that you can move your mouse and pull up a "full screen start menu". The same spot puts you back on the desktop, so it's not gone it just looks different and has some functionality that's tough to get used to.
I like the idea of connecting everything into the "start menu" but wish something like facebook was integrated properly as well as being able to have a google search button.
The overall look of it is much nicer and my animated background is gone but i'm sure stardock will come out with something.
pro: looks clean and full screen
con: hard to get used to (can't even shut down without several clicks or ctrl alt del)
conclusion: worth $15 and if I can't stand it i'll reinstall.
Not to get all, get off my lawn!, but again I have been using all forms of UI's for a long time now. I am not just used to "navigating Windows in a certain way", rather I have seen what tends to be efficient and what is not.I would have to disagree, but I will admit there is a steeper learning curve with mouse/keyboard interaction. But to call it inefficient is reaching. It's more of the fact that you're used to navigating Windows in a certain way with the mouse & keyboard so there's a muscle memory issue. I've been using W8 since the Consumer Preview and I've ran it as the primary OS on my laptop and not to pretend that I was sold from the get go, but now I honestly like the new Windows 8 navigation.
...MS is forcing this change. Ask yourself why.
Like how the PC gaming market was due to die 5 years ago? Golly gee Lassy! Better get Timmy the Toyboy out of the well because PCs are gonna die!...that the desktop PC is destined to become a niche market ...
Look, I'm not going to call you a MS shill...but ok; you kinda look like an MS shill.
