CrashOv3r1De
Disabled
- Jul 21, 2003
- Brooklyn, NY
Also if I had to go prebuilt should I go with the koolance exos or the hydrocool 200
Can't be said any better than that. Don't waste your time and money with pre-built systems. Both of the systems you mentioned can be outperformed by decent aircooling.If you don't want to learn but just want to Buy stuff, believe me, the above list WILL get you a system that is better than any kit or pre-configured system for sale by anyone.
I've got a couple myself, and they do run very quiet(24v on 12v), but not any quieter than my 120mm with a rheostat turned all the way down. They're also very big in both width and height, and this poses more problems. They're too wide to fit in many cases, and are in fact larger than most heatercores. They're not a bad option at all, but probably not worth the effort for most.I say more people should look into 172mm fans, and make shrouds for those
CrashOv3r1De said:maybe you can show me a site that has parts and ill try to build it
Nick Burns said:I want to build a water cooling system, but I want to keep it external, any ideas or links on how to do that? Also, how do I set up the relay? Or whatever it is called where the pump and fans start going before the computer gets turned on.
