- Jan 31, 2012
- Houston, TX
Alright guys, let me start by telling you my setup, how it flows and then what I am wanting to do.
I am running an i7 2600k overclocked to a stable 4.9. I am also running an XFX 8800gts 512mb( I know it's old but gets the job done. I am not a gamer and have never gamed.lol) Okay, the setup I have is a Swiftech MCR 320 Drive Rev 3(res/rad/pump combo), Swiftech Apogee HD, Swiftech Stealth VGA and Primo Chill 1/2" ID 3/4" OD.
When I was running just the CPU water block my idle temps where 32c. Obviously, now that I added the GPU into the same loop as the CPU my temps at idle have escalated to 38-39c which bothers me.
I have a Xigmatek Elysium tower so room is not an issue As of right now my Drive Rev 3 is mounted to the back of the case because that is the only way it can be done and still fill up the top mounted res. So from my readings and common sense the only way to get my temps down is to by another rad, supplying more cooling surface area. I am going to get yet another 360 radiator. Yes I know have 2x360 rads is overkill for a CPU and single GPU, but I am future proofing it for later down the road when I add more GPU's and chipset water blocks. I have read the test at Skinnee Labs about the 7 radiators that they tested.(great review BTW)
What I am wanting to know is for my setup what 360 rad would be the best? I need a low FPI rad that is not so restrictive. I am geared towards either an XSPC or another Swiftech. What would you guys suggest and why? I want my temps a lot lower than they are now.(cost is not a problem, I want performance) Also where in my loop should this rad be placed? Right now my loop is as followed. Obviously my res is ontop of the rad which is ontop of the pump.......so Res-->Rad-->Pump-->CPU-->GPU-->Rad. Size is not an issue either as I have plenty of space.
Will my Swiftech MCP35X be enough to supply that loop size I am wanting to go with?
I have another question relating adding a reservoir to this setup, but let's answer this one first.
Thanks in advance,
~M4H
Thanks in advance,
~M4H
