- Oct 18, 2002
- Ontario Mississauga
about the temps i have a theroy, maybe ati increased the volts for gpu etc for video card so when ppl use the ati program to o/c it would be stable??? its just a theroy dont go screaming at me.
jrbob said:
People should reed up before thay start going off, because it is right in the driver release notes what the drivers do.
Check it out
http://www2.ati.com/drivers/Catalyst_38_Release_Notes.html
ATI OVERDRIVE
The new ATI OVERDRIVE (patent pending) tab, currently available for the RADEON™ 9800XT only, provides a safe and intelligent graphics processor clocking utility. ATI OVERDRIVE is constantly monitoring the graphics processor and pushing the graphics frequency to its maximum, while always ensuring that the processor temperature stays at a safe level. If the temperature of the graphics processor were to become too hot, ATI OVERDRIVE automatically decreases the clock speed until a safe temperature is reached. ATI OVERDRIVE never reduces the graphics processor speed below the pre-set factory default clock speed.
There have been zero reports in our customer support of monitors dying.
MassiveOverkill said:If your monitor is new and has a feature that won't let it use a refresh rate that it can't support, you won't be affected by this (as far as it affecting your monitor, not the overheating issue).
I assure you, that if your monitor doesn't have this protection, and your 3.8 Cats are indeed running your monitor at refresh rates out of spec, it's only a matter of time before it goes belly-up. I suspect, older monitors like mine, that have been around the block will die alot quicker than a newer one.
Silversinksam said:
I don't know if I buy that since XP users get set to 60mhz by default after installing any catalyst driver set, including the Catalyst 3.8.
I am an ATI user at this time as well as being an NVidiot and I am just telling you my thoughts regarding this. It's my opinion ATI has a better card in terms of price and performance over the competition, thats the reason I have an ATI card.
Actually, there is a utility included with the Omegas that overrides the XP/2000 60 Mhz refresh rate problem. And even if you didn't use this utility, your only at 60 Mhz in desktop, when you're playing games at higher resolutions, your refresh rate changes accordingly.
Don't get me wrong, I love my ATI card, but I truly think someone in their engineering dept screwed up this time. I highly doubt that they test their cards on older monitors, and they probably have the newer, expensive monitors that support the refresh rate protection feature.
