- Jun 13, 2007
Is that personal or fact?
it is a hell of alot cheaper aswel
it is better.
the only top that beats that one is the EK Xtop Rev 2. but that one doesn't have a res.
i normally get 10 feet per build i do. i end up with about 3-4 feet left over. better safe then sorry.
i don't see fittings (unless you plan to add the option when you check out)
don't see fans.
also grab a silver kill coil and or pt nuke.
other then that your fine.
#Laughs# spawn - that first line sounds like some 1950`s joke I think you just need to insert "funny thing was" just after that full stop #Chuckles#
Edit: ROFL - does it happen everytime you do a build, ROFL - some more
spawn in carry on cooling... #Chuckles#
I asked on my other post what sort of fittings i will need?
also the fans i will decide later unless anyone has a idea of what would be good in push pull?
what is the silver kill coil and pt nuke for?
thanks.
don't see fans.
So both are safe really, just want to make sure everything is right as its my first time with water
