hey guys,
I am looking to WC my system.
This is my list, its gone a little over $400, my range was more on the $350 side.
Now if you guys think I should get something cheaper that would work gr8, that will appreciateable. Is this list good:
CPU BLOCK:
Swiftech APOGEE Water Block
http://www.bigfootcomputers.com/Mer...en=PROD&Product_Code=6238&Category_Code=510.1
$64.98 + Shipping ~ $75
GPU BLOCK
Danger Den MAZE4 GPU Block
http://www.memoryexpress.com/index....dProductDetail.php&DisplayProductID=8116&SID=
$64.95 x 2 ~ $129.96
RADIATOR:
HW Labs Black Ice Xtreme II Radiator
http://www.memoryexpress.com/index....dProductDetail.php&DisplayProductID=8432&SID=
$89.95
PUMP
Danger Den DD-D5 12V DC Pump
http://www.memoryexpress.com/index....dProductDetail.php&DisplayProductID=7765&SID=
$99.95
TUBING:
1/2in ID Tucing
http://www.memoryexpress.com/index....dProductDetail.php&DisplayProductID=8115&SID=
~ $20
EXTRAS:
T Line + Clamps + Plug.
Local Hardware store
~ $5
Thanks, I was thinking of getting this one from DD, its actually cheaper : http://www.dangerdenstore.com/product.php?productid=170&cat=69&page=1 I know its a TDX block, but I believe its the same performance as the apogee.
Anyways plz let me know.
Thanks guys
CPU BLOCK:
GPU BLOCK
RADIATOR:
$89.95
PUMP
$99.95
TUBING:
1/2in ID Tucing
~ $20
EXTRAS:
~ $5
Thanks guys
