- Thread Starter
- #21
I will! I had just over looked it and went straight into the water cooling section. Sorry about that.IMOG said:Maybe I'm missing something, but isn't it not ideal to pelt your GPU but not pelt your CPU?
The GPU and pelt will be dumping loads of heat into the loop, and your CPU temps will reflect this.
Also, if you haven't already done so, check out our extreme cooling forum, as there is a lot of useful information there, as well as people who are very interested in just what you are trying to do.
Well the reason for this backward sounding "peltiering" is currently I am going to only cooling the GPU. I am waiting for the A64-FX55 to come out and show me what its got before I dump that kind of money on the CPU, untill then my system is a lowely 1.7 Willamette P4 cpu on a 423 socket. I don't care to water cool it. I am close to upgrading it any way, but I am going to get my cooling system up to par before I upgrade the CPU and try to wait out the market a bit more. The pelt is more or less something very interesting to play with and if it it does work well enough I will continue to use and add them when I upgrade. If nothing else I can more or less down grade the GPU block if I feel or find that it will affect my CPU too much. Either way I want water cooling over air
