hi guys im planning to build my first water cooling setup and i need your help
My Spec
Case: Antec 1200
Power Supply: Antec 1200w
GPU: GTX 480 SLI
CPU: I7 930 OC 3.8 with V8
Memory: Gskills 2000mz running at 1450 cant get it higher
Hard Drives: 3 50gb OCZ Agility 2 in raid 0, 2 Raptors 150 gb in raid 0
Motherboard: Asus p6x58d premium
sound card: Sound Blaster X-Fi Titanium Fatal1ty
and i want to Water cool my CPU and 2 GPUS in one Loop
here is what i came up to so far:
1) XSPC Rasa High Performance Acetal CPU Liquid Cooling Block (Sockets LGA 775 / 1156 / 1366)
2) XSPC Dual 5.25" Bay Reservoir - Laing D5 / MCP655 w/ Blue LED Light - Clear / Silver / Black
3) XSPC RX360 Triple 120mm Radiator
4)Koolance VID-NX480 (GTX 480)
can it be done to keep evrything cooled or do i need to do 2 loops
1 is for cpu and 2 for 2 Gpus?
what would be the best setup ?
all the fittings and tubing i have at my work so im not going to order them
and also what size tubing should i use?
and if you can please post the links where i can buy all the stuff
Thx alot for your help guys
My Spec
Case: Antec 1200
GPU: GTX 480 SLI
