- Jun 24, 2001
- in the garage
Does anyone know if water wetter is worth it? Apparently it helps in heat transfer and stop corrosion. But it goes for like $13 +s/h. Is there an equal/better/cheaper solution to these problems?
mechsiah said:I have heard (so don't shoot the messenger) that you can achieve a similar effect by using a drop or two of dish soap. Evidently the soap breaks down the surface tension of the water in the same way that water wetter does.
Do not try this without confirming it elsewhere though! I could be talking out my azz. (My most reliable source!)
has any one ever just tried distilled water?
r0ckstarbob said:remember, in heat transfer, we're passing temperature from one side of the metal to the other side. other microscopic things come with it.
