- Oct 28, 2006
- Raleigh, NC
Hey, I'm thinking about getting my feet wet, but can't find enough info about what kind of radiator I would need. Right now I have my specs in my sig. My i7 is at 3.99GHz with 1.31 vcore. It idles between 36-39C, and loads about 70-75C with HT enabled.
I will be watercooling my CPU for now, but plan to add two GPUs to watercool later. I am getting a new case for this, and was eyeballing the Antec 1200, GTZ CPU block, and going for two loops. However, I have tall plans for my i7 by pushing it to 210-220 (HT off), and don't think a small rad would cut it for just the CPU. I have been thinking a PA160 mounted to the 200mm Antec fan, but I have doubts about it. With this setup, I would put a 120.3 rad up front with my 3 HDDs for the second loop.
But, recently I have been thinking about moving the hard drives to the back fans, and taking up the entire front with a single 120.4 for everything. In either case, I'd be using medium panaflos for the 120 radiator.
Also, if any parts are a problem, its not a problem. Nothing is purchased yet, so it can be changed. And if anyone has suggestions, it is greatly appreciated
