Glad I could help out. I ran into the same problem until I stumbled upon that block. You might have a bit easier time finding it in the US. I had to order it straight from Germany since Canada suppliers are pretty limited to say the least. I'm a little jealous of the options you guys have.
I'd get the backplate for the video card too - http://shop.watercool.de/epages/WatercooleK.sf/en_GB/?ObjectPath=/Shops/WatercooleK/Products/16064
I'm not sure what kind of budget you're on but check out the Protium Pump Res combo. I bought mine from here - http://www.performance-pcs.com/singularity-computers-protium-d5-reservoir-combo-150mm-acetal.html
You can get clear and different res sizes too. This DOES NOT come with a pump so you have to order that separately - http://www.performance-pcs.com/pumps/singularity-computers-protium-d5-pwm-pump.html
Very high quality stuff and I think it looks really good with lots of inlet options.
I just finished my first ever custom loop as well and went with hard tubing. It's fun and beyond frustrating trying to line up the bends but it's extremely satisfying once you get it.
Here's picture of my setup.
Good luck with the build.
You're going to be cutting it a little close running a slim 360mm if you want to OC both parts or if you're concerned about silence especially. You're looking at 285w stock. My setup at 295w stock with a 60mm rad is acceptable, even going up by 50W with moderate OC doesn't impact it hugely, but fans are very noticeable under load. Fans get outrageous and deltas T jumps quite a bit once I start pushing the card and nearing 400w on the system.
Just depends on your use I guess, but more would definitely be better.
Oh YEAH!! I knew I'd find help on this site! Thanks to all who replied, especially Aflac! I had just about settled for an AIO which would've been cheaper(but less fun) for just cooling a CPU. Now I can get everything purchased and join the water-cooled society.
Thanks again guys!
BTW, here's what I'm thinking, open to all comments/suggestions.
Bitspower CPU Block Summit M Acrylic - Digital RGB
HEATKILLER® IV for GTX 1080 and 1070 FTW/FTW2 - ACRYL Ni-Bl
XSPC TX360 Ultrathin Radiator
Pure Plus 12 LED RGB Radiator Fan TT Premium Edition (3-Fan Pack)
Thermaltake Pacific PR22-D5 Plus Addressable RGB LED 5-Speed Adjustable D5 Pump/Reservoir Combo
Haven't really decided on hard or soft tubing yet. Like the challenge of bending hard lines and the better look but thinking maybe I ought to try the easier soft tubes for my virgin loop.
Hey that's a helluva loop you got there! And that being your first has given me a bit of confidence with my own. How much tubing did you go through before getting it to look that good? In other words if you mess up on a cut/bend do you trash that piece? And I looked at the Protium series combo, but I just couldn't justify paying that much for just that one piece. Thought it is beautiful and seeing yours is giving me pause. Decisions, decisions...
That's a Hardware Labs GTR which is 54.7mm thick. My question is do I use both rads or send the TX back?. I know the more surface area you have for cooling the better right? Or would that be just overkill?
OK so that brings up another question. How is your loop routed? Do you have a rad between each wb? Or maybe have the rads linked together as if it were an enormous 840mm rad? Now that would be awesome! Well, I think I've decided to jump in the pool feet first and do a hardline build. Just have to wait until that Heatkiller GPU block is back in stock. I can't find any prominent reviews for that Bykski block Seems like they are popular in China(?) but the too low price and looong shipping times has me leary.
Anyway thank you for the response and the information, I'm starting to feel a bit more confident I'm not about to fry/drown my computer.
